If the engine won't fire up, but your starter turns over, you may want to check your timing unless you have a check engine light on. If the CEL light is on, have the codes scanned.
If the engine won't turn over with the starter or it clicks, have your battery tested at autozone or advanced auto parts. Replace the battery if it is bad. Else, have your starter tested.
If the engine still won't turn over and the battery and starter are tested fine, you may have a blown fuse, bad ignition switch, or a failed relay.
If the engine fires up but randomly dies and starts back up, you either have a failed sensor, failing fuel pump, clogged fuel filter, bad plugs or wires, or a failing ECU.
Iām happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
