Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I RAN OUT OF GAS WITH A HUSQAVARNA RIDING MOWER AND PUSHED IT WITHOUT RELEASING THE BRAKE IN THE BACK OF THE MOWER, REFILLED WITH GAS AND NOW EVERTIME I RELEASE THE CLUTCH THE ENGINE DIES, ANY SUGGESTIONS?
Anonymous
Level 2:
  • Expert 246 Answers
  • Posted on May 15, 2009
Anonymous
Expert
Level 2:
Answers
246
Questions
0
Helped
260490
Points
748
Hello:
From your Description it Sounds like the Seat Safety Swithc has a Bad Connection or Requires Replacing. The Safety System is Registering No Pressure on the Seat when the Clutch is being Engaged.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Why does my mower shoot foreward when i put it in foreward even with the clutch/brake in and while its in park
It sounds like a belt that's sticking in pulleys or belt not releasing when clutch/brake is pushed down. Is it gear driven or hydrostatic?
May 19, 2015 • Garden
Lawn mower will not shift forward or in reverse
make sure the shift linkage is connected and the brake is releasing properly.
Mar 22, 2014 • Garden
Trouble starting murray riding mower model # 42560x92a
it has to be ignition coil or gas feed ckeck coil by removeing spark plug leave coil wire connected turn mower over see if you have spark if so it is in fuel delivery if not check and be sure ground is releasing on the flywheel brake if it is then check fuel filter if ok rebuild and clean carburator.
I have a craftsman 20 OHV Intek Plus riding mower on the throttle lever is also the choke is above the rabbit and my wife got on the mower and wanted to go faster and pushed the throttle lever all the way...
Hi, it may have saturated the air filter with fuel. Try it without the filter, if ok dry or replace the filter. Hope this helps, regards Phil.
Aug 13, 2011 • Garden
I have a husqvarna riding mower and when i turn it on and release the brake the mower dies and when i put the blade on or give it gas it dies, but for the most part just releasing the brake after letting...
It sounds like the seat switch is not working. This switch must be made by a person sitting in the seat for the brake to be released or for the blades to be engaged. It is possible to start the mower with the switch open.
Gary
Rear Wheels won't move on riding mower when off and in neutral
Sounds like the pins/dowels in your brake caliper have gotten dirty and/or rusty and are not releasing all the way. When I had my shop, we found a lot of these and I or my mechanics pulled and cleaned them then took a drill 1/64th larger than the pin/dowel and ran it through the holes in the caliper, NO MORE PROBLEMS!
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
