The screen is off center making the task bar at the bottom drop off the screen while the top of the screen has lines and is blue in color.
SOURCE: light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
SOURCE: printer port for my new hp pavilion dv7?
You should be able to use a parallel to usb converter heres one in the link. There hard to find most are usb to parallel but this should work.
http://www.usbtech.com.au/product.php?productID=GW-K200
SOURCE: how to put hp pavilion dv7-1245dx key back on the
They just snap back on but notice if the key is broken then what you need to do at this point is by a replacment key or buy a replcement keyboard.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: how to replace the lcd for hp paviliion dv7-1130US
Hi There !!
Thank you for choosing fixya.com
I also do disassembling of the LCD's & it's hard to find it on the google. But here's one tutorial that, could help you in some way or the other to disassemble it. Check this out. This is good resource.
http://repair4laptop.org/disassembly_hewlett_packard.html
Hope this will be informative.
SOURCE: i need to conect a fire wire to hp pavilion dv7
I can't recall on that model but I don't think they come standard with Firewire port.
You can get a USB adaptor but they are slow, slower then USB.
Your laptop probably had a PCMCIA slot on it that you can plug a Firewire card into. This is your solution:
http://www.firewire-1394.com/cards-firewire-laptop-notebook-cardbus.htm]
http://www.newegg.com/Product/ShowImage.aspx?CurImage=39-200-004-01.jpg&Image=39-200-004-07.jpg%2c39-200-004-01.jpg%2c39-200-004-02.jpg%2c39-200-004-03.jpg%2c39-200-004-04.jpg%2c39-200-004-05.jpg%2c39-200-004-06.jpg&S7ImageFlag=0&WaterMark=1&Item=N82E16839200004&Depa=0&Description=Rosewill%20RC-603%20USB%20%2f%20IEEE%201394%20PCMCIA%20Card
