The brake lights are not working
SOURCE: why won't my MB ml350 brake lights work even after i install new bulbs?
Did you check the fuse? Either the fuse may be out, or the brake light swith on the brake pedal may be out or need adjusting. You should have 12 volts at the brake switch.
SOURCE: brake lights on mb ml350 don't work even after installing new bulbs
Rick,
The brake lamps on your Mercedes are computer-controlled. I would recommend scanning your computer network for possible fault codes.
