I paid $50 for a complete tune up. I picked up the machine and it was working fine. Then it ran out of gas. I added more gas and from that time, it shuts off after few seconds. Any advise would be greatly appreciated. I called up the repairshop and they told me it could be bad gas. Any advise on fixing this problem would be appreciated. I don't want to spend more money on this.
Hello:
It Sounds like the Gas was Bad or there was Water/Trash in the Gas.
Remove the Carburetor Bowl and Check for Water/Trash.
On Some Models you can Use a Combination Wrench and Remove the Bowl Retainer Bolt and Allow the Bowl to Drop Enough for the Gas to Flow and Flush the Bowl in this Manner.
**Be Carefull, Please. Gas is Dangerous.**
On Other Models you have to Remove the Carburetor from the Engine for Servicing.
>>You can View a Breakdown of this Unit at this Site Addy; http://www.carlsequipment.com/ and Select OEM Parts at the Top of the Page. Now Use the "OEM Parts Diagrams Look Up by Model Fit" Section. Select the OEM (Toro Consumer). Select Snow Throwers. Select your Model. Now you can Select the Section of this Unit you Wish to View by Select it from the Drop Down Menu at the Upper Right of the Page that Loaded After you Select your Model.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
