I've installed a PCB, Mixer Assembly - CD Mix-2/3 704-MX3-5872. and I have a problem with a 2 wire harness (r) red & (b) black that attaches to the PCB, Control/Display (1st version) - CD Mix-2 704-CDMIX2-3174. I don't know if the (r) wire connects on the left are right side. When I connect it either way it lights up...I just want to connect it correctly, to avoid future problems.
Thanks
SOURCE: Numark cdmix2 bpm counter
its for the count of a cd hit it on button sumware tap it in touch of speed temp o u wanna use beat match to anther cd bit count ok so tho both match up speed dual mode
SOURCE: Numark CD mix 2
Hi aondj
I would remove the back panel, and get access to the soldering of the connectors that are giving you trouble. resolder them, and see how you go. Get back to me here if this does not cure it and we shall get into it further
regards
Graeme
SOURCE: numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
SOURCE: Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Also on the PCB, Control/Display (1st version) - CD Mix-2 704-CDMIX2-3174 the marking is CN202, IR1 & IR2.
