HP Mobile Remote Control For Pavilion Dv4/Dv5/Dv7 Series PC  Logo
A
Anonymous Posted on Dec 18, 2013
Rc6 ir driver - HP Mobile Remote Control For Pavilion Dv4/Dv5/Dv7 Series PC
1 Related Answer
Anonymous
  • 72 Answers
  • Posted on May 23, 2011
SOURCE: Hello, I am searching rc6
Hi, the drivers you are looking for your HP Pavillion DV7-1170 IR receiver are located here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
I have a hp rc6 remote control but it is not working with my elitebook 8440p i want driver ... please tell me how can i get its driver from internet ?
did you get the RC6 with the PC new or are you attempting to add it. ?
HP MEDIA Center rc6 remote,
control,
way post and not say OS,?" is this XP, VISTA or W7?
and did you ever upgrade the OS or replace the HDD.?
all history matters. we can't see what you have !
so..... tell it. please.
there are 6 drivers is way,,, ( or just 2) 1 for XP and 1 for vista /w7
try a new battery? in it, be like first. think.always.
the drivers are NOT on the internet they are at HP,
its 100% custom HP hardware here.!!!
you are not asking at HP, why? this is fixya , has zero to do with HP ever. ever go to hp support forum and ask. be wise no?
HP real
https://support.hp.com/us-en
now all your drivers for that PC.
one post says
Try installing the "ENE CIR driver" on the link below.
the hp support page has no driver there, for this feature.
its an error that. or Im on the wrong page.(easy lacking full service tag data)
HP puts most of these drivers under
Keyboard, Mouse and Input Devices
SP41705.exe supports below (note the secret FTP links)
ftp://ftp.hp.com/pub/softpaq/sp41501-42000/sp41705.exe
Windows 7 (32-bit)
Windows 7 (64-bit)
Windows Vista (32-bit)
Windows Vista (64-bit)
MY wild guess is this PC is a media center edition?????
there is no MCE, page at HP for this exact PC, only generic.
and no such file listed there. thus HP, FTP links to lost files.
endless hits on this missing RC6 driver, here.
mostly do to owners changing the OS and not loading the HP drivers off your HP driver page.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=++ENE+CIR+driver+
1helpful
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Download driver free
How old is the battery in the remote?
Need to find code for technica tv video with cpc rc6 remote
Google the model number to see if compatible with each other--remotes only have so many possible codes and may not program for all brands or models.
Looking for directions on using the canon RC6 remote..(camera settings) ..I have a 5D Mark II thank you
Press the [AF-DRIVE] button and select the self-timer mode. Point the remote controller toward the camera and press the button.
Full details are in the "Remote Control Shooting" section of the camera manual (page 102 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/0/0300004270/01/eos5dmkii-im4-en.pdf
1helpful
3answers
How do u use the rc6 for instint photos not two second. What do you set on the camera. 5D mark ll
don't set for 2 sec, set the camera to 10 sec self timer and click the remote, should work instantly with every click. just remember to set for regular shooting if not using the remote. can be very annoying to wait 10 sec for a shot, unless you want to be in one?
9helpful
2answers
Hello, I am searching rc6 ir remote control drivers for hp pavilion dv7-1170us(win 7).... Please help me out to solve my problem
Looking for codes in philmore pm-rc6 7-in-1 universal remote tv is Sanyo
This states that that remote is not a Universal remote but then contradicts the statement.
https://www.amazon.ca/Genuine-Philmore-PM-RC6-Remote-Control/dp/B01JJBGNCE
These are the Sanyon codes. The first one is the most common. The universal code for most is 049 for a Sanyo TV
Brand Code SANYO 2 more rows
universal remote codes for sanyo tv - DirecTutor.com
Unlock region for HTS3372D
check thi web site it will help you, http://home.hccnet.nl/r.de.haas/RC6/index.html
Change area code of device please
1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
2. Enter RC6 command via Pronto
[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
2.1. The remote should be set up to control the DVD (setup code 0539).
2.2. Press the DVD button.
2.3. Press the Magic button.
2.4. Press 085.]
2.5. The display should read '----'.
2.6. Enter the following with the normal Philips remote:
[On newer models, there appears to be 11 spaces in which to enter a code].
222 222 005 255
The player should now be able to output pal progressive scan + be region-free.
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
