SOURCE: Aficio 1035 ps
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
SOURCE: how can I find a schematic design of Lanier Model 5635/5645 Copie
Goto my website and Download the file from the Public Folder. It is the only Point 2 Point in the folder.
Do not forget to vote Yes or No if this information was helpful
www.copytech21.spaces.live.com
SOURCE: meter reading
2 ways to check the meter.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
SOURCE: copier
I'm way late..... but the used toner is located under the transport belt assembly. Remove belt assy., and vacuum out waste toner -clean sensor on bottom of unit.
SOURCE: I have a Lanier 5635 and its not working. The
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
