Jacuzzi 7.5 GPM 180000 BTU Internal Gas Tankless Water Heater Natural Logo
A
Anonymous Posted on Dec 18, 2013
Water leak internal - Jacuzzi 7.5 GPM 180000 BTU Internal Gas Tankless Water Heater Natural
1helpful
Plastic plug is leaking on the top of electric water heater. Whats up?
excessive internal pressure or just a bad plug. Try replacing the plug.
How to repair leaky hot water heater
leaking is a sign of rust internally
cheapest fix is a new hot water system
Water leaking
Check all external pipes, includeing the ones at top. If you find no pipeing leaks, the odds are, depending on age and waranty, you
have an internal tank leak and need to replace. There is virtually no way to fix that kind of leak.
Leaking from the bottom, model was built in September 2001.
Replace. There is no fixing an internal leak
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Water is dripping down one of the 3 feet under the heater. Does this mean it needs replacing?
make sure that the water is not coming from the over flow tube or the drain valve at the bottem of the tank first. If it is not then yes there is an internal leak and the tank should be replaced
Top Jacuzzi Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Jacuzzi Water Heater Expert? Answer questions, earn points and help others
