Haier HWD1000 Logo
I need to know what wires go to the door switch it has numbers 1-7 what color wires go where
GTD72EBPN0DG ge 2019 electric dryer, anyone know which colors from the door blue and yellow connect to the wiring harness of pink and blue
If you only have two wires, it really shouldn't matter. The door switch is just an on or off switch. I would go from blue to blue and then tie the pink to yellow.
Wire color position for 2002 Nissan Altima window switch
Normally I recommend anyone serious about working on their VEHICLES purchase the FACTORY+WORKSHOP+MANUAL.
Luckily you will find BBB Industries has your circuit drawings ... wire colors and numbered tabs... to assist in-screwing what ever is BROKEN NOW...
You have "auto" up/down and the DRIVERS DOOR get a little less use than the SAFEWAY STORES front door...
Go to bbbind.com... wade thru the registry... go to their wiring and technical service bulletins...
Re-check that you are in "WIRING DIAGRAMS"...
"BODY & Accessories" and go to "POWER WINDOWS".. you are there...
BBB Industries Premium Alternators Starters Power Steering Products
I'm good with all the "color" letters but "L"
(I'm guessing "lime" trace??)...
You tell me... Hope this helps!!
Old motor wires are numbered new motor wires are colored this is a 1/2 hp reversing motor for a overhead door
Single Phase Terminal Markings Identified By Color: (NEMA Standards) 1-Blue 5-Black P1-No color assigned 2-White 6-No color assigned P2-Brown 3-Orange 7-No color assigned 4-Yellow 8-Red
1helpful
Wiring code for ceiling fan
These fans do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
3helpful
3answers
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
1998 4runner radio wiring harness
Constant 12V+ Blue/Yellow or Blue/Black Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5 1/4" Rear Doors Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
1helpful
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
