Red light comes on now and again, and sometimes the yellow light. Have noticed a layer of ice underneath the bottom drawer which I have removed and lowered the temp to 20 deg. Is this a problem or the freezer coping with a full load?
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
SOURCE: Ice collecting under bottom of Freezer drawer
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
