Cke media detect sensor which is mounted inside of cleanout.
clean the sensor or replace the sensor..
1. Remove roller cover upper & roller cover lower
2. Disconnect paper sensor connector
3. Remove clean out (P/no CN727-60047)
4 remove paper sensor..
Here are some tips on how to use the feeder:
- Use paper that is in good condition.
- Fan the paper before loading into the feeder to avoid sticking together.
- Make sure the paper don't buckle when loading into the feeder.
- Avoid overloading.
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
This is caused when the size paper loaded into the machine does not match the size the machine expected. Check the paper size settings to ensure you are using the correct paper setting. This also can be caused if paper loaded does not align correctly.
