CHANGE PASSWWORD FOR TP LINK TL-WR741ND
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
SOURCE: how to change tp link tl-wr641g nat type?
NAT is Network Address Translation.. It is a setting of the router... you need to login to the router navigate to the NAT page and set it to the required settings save and log out
manual below
www.tp-link.com/english/soft/200865140422.pdf
SOURCE: i want to change the
1. you cannot change the firmware to a router unless there is a firmware update from the manufacturer. You can go to the manufacturers site and download the firmware update > but for language change is in the browser that is Internet Explorer or Firefox etc.
2. for Internet Explorer go to "Tools" then Internet Options" then click the "General tab" look for the button that says "Language" locate the add button then add the English from the list and click apply this should change the language from Chinese to English when you view the router page using 192.168.0.1 or 192.168.1.1 depending on the manufacturers settings.
the same should be in all browser for language changes.Check the "helps" for more information > usually a "?" to view the content or the word "help".
SOURCE: how to configure TP-LINK TL-WA730RE
you can get the manuals of how to configure tp-link tl-wa730re..just go to google and type free tp-link tl-wa730re manuals.
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
