If it is a universal remote control, just try to set it with an other code stated for Sinotec TV, in the remote controls' code list. Check all the codes said there, and choose one code, which give you maximum functionality with TV. That is all to do; and is the way too.
google.com/+GopakumarGopalan
SOURCE: ILO-26HD
We had bought the extended warranty, so we took it back and got a new TV of a different brand. We had to pay the difference, but it was worth it. The warranty even carried over to the new TV.
SOURCE: phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem.
This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
SOURCE: My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Testimonial: "thank you sounds greek to me and costly but I guess I have to do what I have to do-----have you ever heard of a video IC board?"
SOURCE: Panasonic Plasma TH42PZ80U - Picture Reset Mode issue
don't do the latter, just do the take-it-to-the-tip thing.
SOURCE: Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
