Check your AC Adapter for voltage output using a multi-meter. If voltage is lower than stated replace Adapter. When replacing adapter verify Amperage is same before purchase.
I think if you do not have a recovery disc then the operating system needs to be reinstalled. It is also possible that the system needs a virus scan if there was a case of malwares within the PC.
This is the only card that works in the mini-PCI slot in the 1905 series. eBay would be your best bet. You can look under "Toshiba 1905 wireless card" but ... make sure it's an Agere card, as most sellers are selling Intel, Broadcom, Atheros.... and none of them will work.
What type of router do you have? Is it a B, G or N? The Belkin Play's will not work with B-Router's.
It could be the adapter itself. If you just purchased it try exchanging it and see what happens with the next one.
I hardly ever recommend Belkin anything....I have and will always use Linksys.
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
