I cleaned the screen with windex, now there are streaks and black spots forming at the bottom of the screen, did I damage it permanently? I didn't spray the windex on the edges, and I was trying to be careful not to get any liquid on the edges. The screen doesn't have a clear protective screen covering the ridged screen.
Windex is not the best cleaner. Bed and Bath Beyond has a very good NON-Streak class cleaner that I tell my customers to use. The best solution is NOT to Spray directly onto the TV Screen. Remember the glass is only delivering the picture from an RGB projection unit sitting inside the enclosure. It is not the electronic projector and the screen is separate. It can be replaced if damaged; however I believe it is only streaked and needs proper cleansing. If you get the new cleaner, spray the solution onto a soft cloth and wipe the exterior screen. Promptly wipe it dry and if you need to do this a few times, eventually you will get the glass clear and enjoy the show.
Testimonial: "Thank you again"
SOURCE: too much windex sprayed onto screen of Grand wega- black blotches
Thanks for your kind words and suggestions.., It turned out,, That after 12 days it finally cleared totally away and I now have no spots., or black spots. It started to disappear after a couple of days but took more than 10 days to appear to be evaporating..
SOURCE: liquid under screen on mitsudishi dlp tv
With a conventional projection type screen on CRT type televisions this is not a problem,but with the newer DLP type screens the fiber of the Fresnal screen acts like a spounge and soaks up any liquid introduced.If you try to clean it it will smear and make it worse.You can remove the screen assy an clean it with Windex but allow it to dry properly.I do not see a problem with cleaning this screen,but make sure you put the screens back the way they were.I must also note that it is no easy task removing this particular screen assy.Good luck
SOURCE: Mitsubishi TV Screen Water Stain Problem
You can use warm water and a soft cloth to try and clean it, but it will probably leave some evidence that liquid existed between the two layers at some point. Mitsubishi will deal screens directly to their customers if you ask nice enough and are willing to install yourself.
