First of all, Paul, I recommend not posting your email address as a question, its very unhelpful for others to find and help you with.
Secondly, Can you give more information as to what is keeping you from logging in? Do you have access to your [email protected] email account, but not the ability to log in to facebook?
In general:
1. go to facebook.com
2. plug in your email or phone number + password in the boxes on the upper right hand menu
3. or if you have forgotten your password, hit "forgot password". password reset instructions will be sent to the email on file.
4. Otherwise, follow the main instructions on the main page. Make sure you have access to the email you use to sign up.
5. If you no longer have access to the emails on file for that facebook account, there is a button at the bottom of the "forgot password" page, which you can click and enter a phone number for other means of resetting your account
GoogleI can't access my account. If you are having problems accessing Gmail, please follow the troubleshooting steps below to resolve your issue as quickly as ...
GoogleI can't sign in to my personal Gmail Account. You can be signed ... We encourage you to use your work email address ([email protected]). If you don't have a ...
Google
Oct 23, 2010 - 15 posts - 6 authors
Therefore, I can't access my gmail inbox or get to my mail there. ... problem, I was able to access my GMail inbox through a Google Account that ...
Google Email: Can't log in or access anything Google:
Hello. Yes, once you log into your Google Account, you will have access to all things Google. Without that account login you will not be able to access anything Google related except Google Internet Search.
As a temporary fix, so that you have access to Google Services, create a new Google account.. Settings>General>Accounts>Add Account>Google
so, think of another name you can create the new Google account to be.. I would pick your last name first then first name and a number (eg: [email protected])
i would use the same password or a password you can easily remember for the time being so that you don't get mixed up/confused
then use this new Gmail account to temporarily get Google services back. it won't be your original account with all your data, but at least it allows you access NOW to whatever you need it for (like to access Google Play Store so that you can install an application to use on your smartphone)
on a piece of paper or in a notepad app on your phone, write down your new Temporary use Gmail account name and password, so that you don't forget and so you can login again if need to. (We will log out when we try to fix your original account)
when you find time we can try to get back into your old account so that you can access your emails, phone contacts, etc that's stored in your original Gmail account
CreateNewGoogleAcct.mp4 (note: depending on the device used, manufacturer, Android software firmware version#, and cellular service provider.. the settings menu system may look a little different. Keep this in mind when following instructional tutorials of a different device then yours)
Procedure to: GET BACK INTO YOUR ORIGINAL GMAIL ACCOUNT:
Open your internet browser:
If you forgot your password, you can reset it, go here: Having trouble signing in
(to reset password, OR to get a hint to remember username)
(if need to, you can use your new alternate temporary Gmail account to have Google contact you)
or, you can use this Google Access Troubleshooting form: can access my account
(it looks like the image below)
** After you reset your password, then Go back to your phone settings: Settings>General>Accounts>Google.. Click on your original account name (not your new temp account) and enter your new password you reset to for your old account
*** You should be able to get back into your original account.. If YES!
..then we need to remove the temp account, so that we don't get confused and everything is back to normal.
(you can keep this info for your temp account login somewhere in case you need it again if want. or, use it as a dummy email for telemarketers, people who want your contact but you don't want to talk to, etc)
Go back to: Settings>General>Accounts>Google
tap on your temporary Gmail account name/address
Tap on the 3 dots (upper right corner):
Select "Remove account"
You would basically have to create a new account. With Gmail this isn't just a login, but the entire account's identity. Depending on how established the original account is, you may not want to go through the hassle of changing it. If it's relatively new, then I'd get the one you really want locked in ASAP and make sure the people you interact with have that contact info.
If you do t use it for Gmail access and just use it for access to other Google services then change it. No big deal.
Hope this helps, don't forget to rate or respond with a follow-up question.
