Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
