Singer 7462 Mechanical Sewing Machine Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a zipper foot
I have Merrit sewing machine bought in 1974 I have lost the instruction manual, it has no number just says Merritt made in Italy on the front. I need a zipper foot but can't get one, John Lewis said the one they sell wouldn't fit an old Machine!! Can anyone help??
Anonymous
Level 2:
  • Expert 323 Answers
  • Posted on May 15, 2009
Anonymous
Expert
Level 2:
Answers
323
Questions
0
Helped
146420
Points
830
Go to any sewing machine store and buy a LOW SHANK adjustable zipper foot.This foot will screw on and fits almost everything. Yes, it's an older machine but you can still get most parts for it. Especially feet.I think this machine has snap on feet, so If you want an original foot take the ankle with you when you go to the shop to buy it.
sewman7
How to drop feed dogs on a singer Maritt sewing machine
Most Singer Merritt sewing machines do not drop the feed dogs. Instead, you place a cover over the feed dogs. Here's one replacement for the cover: https://www.sewingpartsonline.com/feed-cover-plate-singer-360-sewing-machine.aspx . This fits the Merritt 2404 and Merritt 3130, among others.
Many Singer manuals are available here: https://www.singer.com/support . You need the model number to find a manual. The Merrit 2404 manual is here: http://www.singer.com.br/wp-content/uploads/2014/02/Singer-Merrit-2404.pdf .
Please add a comment with the model number of your sewing machine to find out if a different feed dog cover is needed for your Merritt. I hope this helps.
How to adjust needle from left to right using zipper foot on ELNA 7000 sewing machiene
The instruction manual should have that information. If you don't have one, you can get it here:
Elna Sewing Machine Instruction and Service Manuals
Machines either have a needle that will move right or left or the zipper presser foot will adjust right or left.
Re: Pfaff sewing machine, How do I use the zipper foot attachment?
It really depends on what your zipper foot looks like. There are several that can be used with the Pfaff machines.
Pfaff Zipper Foot 4
Pfaff 1067 zipper foot instruction Google Search
How do I thread the Singer merritt Lock serger?
Which model is your sewing machine? There may have been several with the Merritt Lock name. The 14U44 Merrit Lock uses the same manual as the 14U44B. The manual for 14U44B UltraLock model is available from Singer here: http://www.singerco.com/uploads/download/4268b9ecf6c0ad26e8810365518e68cfea086994.pdf . See pages 10 - 17 (12- 19 of the PDF). There's also the 14U44B manual here: http://www.singerco.com/uploads/download/1292_14u44b,244b.pdf . The threading diagram is on the same pages. I'm not exactly sure which manual will help you. Additional manuals are available here: http://www.singerco.com/accessories/instruction-manuals . Enter the first part of the model number (up to any alphabetic characters). You can order copies for $15-20, depending on the machine.
I hope this helps.
1helpful
How to attach zipper foot on singer inspiration
Here is a copy of your manual.
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Most modern machines have snap off and snap on feet. Grasp the foot that is on there and push down. Then while lowering the foot, align the little bar on the zipper foot and watch it snap in. Easy.
Have lost the zipper foot for a pfaff hobbymatic 939 The instruction manual I got with the machine is for a hobbymatic 947 and it looks exactly so I'm guessing the zipper foot would be the same. where...
You should be able to buy another foot, but you'll need to know if it is a high shank or a clip on style. Try this link to www.sewingpartsonline.com http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx they have two invisible zipper feet and two clip on ones. Don't mention your model but you should be able to email and ask if you aren't sure. I'd expect that the feet would be interchangeable between the models in the same era as yours. Just ignore the long funny shaped feet, they are for Pfaff sergers.
2helpful
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
