Hello. I have a SHARP 80inch TV which while watching switched off with smoke coming out of the back. I have confirmed through a SHARP agent that the problem is with the power board however I need the service manual for my TV in order to order the accurate parts. Could someone tell me where I can find it. Thank you.
Well you can get the service manual for this model Here if you pay 19$ for it. or you can look at the affected board and get the part number off it call a service company and find out if they have a replacement in stock.
SOURCE: Sharp Aquos Won't Power On
I have the same problem with my My LC-42D62U WHen i watch certain DVDs, (so far it happened on SAW III and RUNNING SCARED) during certain parts of those movies my TV will turn off and i cant turn it back on unless i unplug it and plug it back in. It only turns off on specific parts in the movie, i have no idea why...like the same exact parts...so i pretty much have to pause the movie with my remote once my TV turns off then when i power the TV on again just resume the movie and its fine...but if i rewind to that part again it'll power off again SAW III only had one part like that....but RUNNING SCARED had about 3-4
SOURCE: 52" SHARP LCD getting a snowy picture after 5 to 10 minutes
Main Board problem. Call sharp or local sharp authorized service center to fix this problem.
SOURCE: tv will not start after power surge
Voltage checking and caps inspection will be the first thing to do.
If you can post the pictures, that will help a lot. Look at the inverter board to see if you are getting 12~18vdc feeding it, also look for caps with leaking/bulging top.
See some pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Testimonial: "Example pictures quite helpful. I do some more visual checks and then post pictures of my power supply and ask for test locations. Thanks"
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Testimonial: "Helpful"
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
