Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
5C00 - Orange and green blinking 4 times
Description:
A service error has occurred.
Resolution:
Turn off the printer.
Disconnect the power cable.
Open the printer cover.
Check for any orange protective tape or white polystyrene and remove if necessary.
Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
Close the cover.
Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The error code 5C00 means the purge unit is broken. To fix this, you have to bring the printer to a Canon service center and need to replace it with new one.
A 5c00 error relates to the sensor in the purge unit, which is where the carriage stops on the right hand side of the printer. ...
Clean all up and where the ink runs on the rollers put a little bit oil on a cloth and run it on the ron the ink runs on, clean every thing you can it may do the trick
5C00 is a purge assembly error, it happens when paper is caught stopping the cleaning blades from working properly, or when the purge unit is just worn out.
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
when i open printer appears error code 5C00
