Here is the location with full instructions:
The module is fastened to the top of the firewall directly behind the
fuse box. It can be reached easily when you lie on your back in the
driver floor area with your head close to the brake pedal. Just look up
and you'll see it is clearly marked and the sticker also displays the
factory-set access code for your truck.
Once you locate the module Make a note of the 5-digit access code on it.
Once you find the code, here is how to program it:
Now that you have the codes follow these steps to operate it completely.
Remember from the driver's door, all operations must start with the 5
digit code first then follow it with the other options.
When pressing the controls on the keyless entry keypad, press the middle of the buttons to ensure a good activation.
IMPORTANT: Every step outlined in every procedure below must be done within five (5) seconds of the previous step.
REMEMBER THIS: If you try the factory code first and it doesn't work try
to reset the keypad back to the factory code. Your personal code does
not replace the factory-set code. So no matter what you can erase
anyone's code back to the factory OEM setting. You can use either code
to unlock your vehicle. Each time you set a new personal code the module
will erase the previous one in favor of the new code.
Deprogramming (erasing) your own or pre-set personal code and leaving only the factory-set
1. Enter the factory-set code. (5 digit) from the sticker on the RAP module.
2. Press the 1/2 control.
3. Press the 7/8 and 9/0 controls at the same time.
The system will now only respond to the factory-set code.
Unlocking the driver's door (also disarms the perimeter alarm system)
1. Enter either the factory-set code or your new personal code. The
interior lights will illuminate as soon as the first valid digit is
pressed.
Unlocking all doors
1. Unlock the driver's door (5 digit code) then press the 3/4 control.
Locking the doors (also arms the perimeter alarm system)
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered.
Deactivating/Activating Auto lock
1. Enter the five (5) digit code.
2. Press and release the 3/4 control while holding the 7/8 control, then release 7/8.
Programming your own personal entry code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
3. Enter your personal 5-digit code.
*#66*# Set Factory Mode CONFIRMED *#8375# Show Software Version CONFIRMED *#1234# A2DP ACP Mode CONFIRMED *#1234# A2DP INT Mode CONFIRMED *#0000# + Send : Set Default Language CONFIRMED *#0007# + Send : Set Language to Russian CONFIRMED *#0033# + Send : Set Language to French CONFIRMED *#0034# + Send : Set Language to Spanish CONFIRMED *#0039# + Send : Set Language to Italian CONFIRMED *#0044# + Send : Set Language to English CONFIRMED *#0049# + Send : Set Language to German CONFIRMED *#0066# + Send : Set Language to Thai CONFIRMED *#0084# + Send : Set Language to Vietnamese CONFIRMED *#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile china *#77218114# *#881188# *#94267357# *#9426*357# *#19912006# *#118811# *#3646633#
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
also ========== Service codes BenQ: software version: *#300# test mode: *#302*20040615#
Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381#
Service codes 3xx, 5xx: software version: *#79# software version: *#837# Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG: software version: 2945#*#
Service codes Sony-Ericsson: J100 software version: #82#
Service codes Fly: 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007#
Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send
Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007#
ZTE Mobile1- *938*737381# 2- PHONE WILL DIPLAYED DONE 3- POWER OFF YOUR PHONE AND POWER ON AGAIN alcatelE205 unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG: software version: 2945#*# KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly: M100 software version: ####0000# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007#
Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language
To restore to factory settings you no need any codes.
Please follow the below steps to restore your mobile to factory settings
Menu > Settings > Restore factory settings
When you select this,It will ask for security code.The default security code for nokia mobile is 12345.If you have changed the security code then type that code.
It takes several seconds to bring it to factory settings.
Please do this.Type *#7370# in your mobile phone,it will ask whether
you want to restore factory settings give yes and it will ask for the
code the default code is 12345.Give the code and wait for some time
your phone will restart and you will see that your factory settings are
restored.kindly rate me if i had helped.
Programming a personal entry code and keypad association to
memory seats and mirrors (if equipped)
To create your own personal entry code:
1. Enter the factory set code.
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. To associate the entry code with a memory setting, enter a sixth digit
to indicate which driver should be set in a memory recalled by the
• Pressing 1 • 2 recalls Driver 1 settings.
• Pressing 3 • 4 recalls Driver 2 settings.
• Pressing other keypad buttons or not pressing a keypad button as a
sixth digit does not set a driver and will not recall a memory setting.
Note: The factory-set code cannot be associated with a memory
setting.
5. The doors will lock then unlock to confirm that your personal keycode
has been programmed to the module.
Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal
code.
Erasing personal code
1. Enter the factory set 5–digit code.
2. Within five seconds, press the 1 • 2 on the keypad and release.
3. Press and hold the 1 • 2 for two seconds. This must be done within
five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5–digit code
will work
