Replacement battery for A220 Feinwerkbau: MODEL 90 (FWB 90) AIR P 504A · Replacement A220/504A (Eveready 504 or NEDA 220) battery is Alkaline · Aftermarket ...
It is helpful if you identify the device, the brand, the model and sometimes the operating system when asking about a procedure or device. By process of elimination, I presume you are referring to removal of batteries from a tablet computer. Most if not all are not designed for simple battery replacement. The batteries may be connected to the hardware by solder. The batteries may be replaced but that requirement makes it clearly a task beyond simple swapping out of batteries. Here is a link:
Mine stopped working about 2 weeks ago (May 2018) after about 8 years of service. I had tried the recommended procedure to depress the reset button on the sensor, but it still would not reset / reboot the temperature sensor. I suspect the non removable batteries to be the issue failure so I am about to crack the case open to try to troubleshoot the issue for confirmation.
the shaver will slow down as the batteries discharge. To suddenly stop suggests either loose batteries or faulty switch. There should be a charging cradle for the shaver to keep it working but if you need batteries then open the battery cover and replace with the same batteries.
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Usually you can save a good amount of money by replacing the battery with one made by a 3rd party. You can find a replacement for most laptop batteries at Batteries Plus.
