I just need a clear wiring diagram and brief instructions for installing the wiring device.... Thx
SOURCE: I installed gfi outlet and I have no power!
turn off circuit, test to make sure its off.
remove the old outlet
black and white wires from breaker attach to line
the wires to the rest of the series attach to load
loop wires to attach in clockwise direction
use electrical tape around outside of outlet to protect terminals.
http://www.thecircuitdetective.com/gfi.gif
http://s44.photobucket.com/albums/f25/silverbird1996/?action=view¤t=GFCI1.jpg
SOURCE: need wiring diagram for 110v outlet: one switched, one always hot
found a wiring diagram online. Realized the hot tab had to be broken (not the neutral tab).
SOURCE: i need instruction manual for a gfci recepticle and switch combin
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
SOURCE: Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
SOURCE: i have cooper combination switch and gfci out let
Hi ,., the two screws on the one side of the combo are for the white , neutral wires, they should be interconnected with a small link. The screw at the bottom of the switch connect the black power wire, then jumper a wire between the other two screws on that side and the switch will be controlling the receptacle.
