Re: how do i remove the date , time, 101nikon 1939 jpg on...
This will always be displayed in your camera. However to choose what will imprint on the pix :
Turn your dial to SETUP and select DATE IMPRINT. Then select OFF (nothing will imprint on pix), or DATE (for just the date to be imprinted), or DATE and TIME (for both time and date to be imprinted)
Setting the date and time in Windows 10 Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen. Click Adjust date/time. Make sure your Time zone is set properly if your computer is displaying the wrong time. To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8 In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time. Select Change date and time settings... in the bottom of the window that appears (shown below). Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button. Make your adjustments and click OK. Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
Published on Sep 17, 2013
1. Turn off the tablet
2. AT THE SAME TIME - Hold the Back Key button ( the one with the arrow) and the Power button.
3. When the android appears let go of only the POWER BUTTON
4. A screen should appear with multiple options in Chinese. Press number 2
5. A screen appears with four boxes at the top and two at the bottom a. Focusing on the top four boxes press the FIRST BOX ON THE SECOND ROW ( bottom left box)
6. Then press the GREEN Chinese character at the bottom of the page
7. A screen appears with four boxes at the top and two at the bottom a. Focusing on the top boxes press the SECOND BOX ON THE SECOND ROW ( bottom right box)
8. The tablet should turn off
9. Wait a couple of minutes before turning the tablet back on.
You can contact Wiltronic Corporation Monday-Friday, 9am-5pm pacific time at 866-599-9888 for any questions or concerns. Or email us at [email protected].
You can set the time and date your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hold down the two right buttons. A
screen will eventually appear showing the watch's current time with the
hour number flashing. Use the top right button to scroll through the
numbers, and push the bottom right button to set the number. After you
set the time, then the date screen will show with the watch's current
date, with the month number flashing. Same buttons do the same thing
here.
Hold down the two right buttons. A screen will eventually appear showing the watch's current time with the hour number flashing. Use the top right button to scroll through the numbers, and push the bottom right button to set the number. After you set the time, then the date screen will show with the watch's current date, with the month number flashing. Same buttons do the same thing here.
A- Top right
B- Bottom right
C- Bottom left
D- Top left
Press C button until you get to the time screen. When the time screen appears press and hold down the D button. The light on screen appears, Press C and the chime on screen appears, Press C again and you can start setting the time using the A and B button. When finished press the D button.
Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen.
Tap the calendar/time icon (the blue icon, second from the left).
Tap the calendar icon at the top of the screen.
Tap
the up or down arrows above the month, day, and year to change the
values. When finished, tap the "Confirm" button in the lower right
corner.
Wait for the the confirmation message to disappear, then tap "Go
Back," then "Quit," then "Yes" to exit. The unit will shut down
automatically to save the settings.
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
I assume you mean date/time right click with the mouse on the time at bottom right hand corner a list will appear left click with mouse on adjust date\time a screen will appear and you can adjust time and date on that screen.
Another way to access this control is left click start button highlight control panel double left click with mouse and double left click on date/time option
Tap the large clock icon (on the right)
Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
Remove all games from the Nintendo DS.
Turn the system on by pressing the POWER button.
Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
