Have you tried waiting a few minutes after this appears? because if you turn it on for the first time, or you have turned it on after resetting it, it takes a few minuted to load. so if you wait a few minutes the main screen should come up.
Press and hold the bottom bar of the square ridged around the central button. This is the bar you press to play/pause and start up the player. It should have a power button symbol on it.
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Firstly, try "re-setting" the Z5 (ie micro switch) first. If this doesn't resolve, then firstly save a backup of all your files...then use the 'format' function (ie open My Computer, then open the YP-Z5 folder, then look for the Format function), which will clean out your entire memory, including hidden files. Then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your Z5. Always update your Z5 with latest firmware (appropriate with your Windows OS). Good luck.
