When not worn for 24 to 48 hours it has to be reset to get the exact time, obviously the watch stops running. After adjusting to the exact time it runs 15 minutes fast every hour.
SOURCE: Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
SOURCE: Watch has been running fine, now running fast.
HI there,
If you have an Automatic Wrist watch. Some adjustment has to do inside the watch. You better bring the unit to any local watch repair shop to adjust or correct the polarity of the energizer.
Hope this helps.
micro
SOURCE: eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
SOURCE: How do I adjust my time
hi friend,
i think your rolex watch must be a automatic one. this kind of watch, you don't need to put battery, after in full power, i can last 24-48 hours. if you wear it, it will not stop, but if you don't wear it for long time, it will stop automatic. to adjust the time, you just need to wind the crown counterclockwise, and then pull out the crown, and then you will hear the sound of "click" and then find the right position, and then wind the crown to change the date. please note that the date have to change from small number to big number. after adjust it, you have to screw down the crown to a good water proof capability.
source form: Swiss ETA watch
SOURCE: my watch runs too fast: adds appr. 1 minute every
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
