Hotpoint RVM1435 Microwave Oven Logo
A
Anonymous Posted on Dec 17, 2013
Change door handle rvm1435 - Hotpoint RVM1435 Microwave Oven
Counter saver plus 62702 kenmore
If you repair a door assy. you are required per DHHS rules to perform a leak test on and around the door after such repair.
The handle of my microwave - rvm125j - came off - i ordered a new one - is it easy to replace myself or do i need to put in a service call. Is there a diagram that shows how to replace it.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The door wont stay shut, the microwave works if I hold the door shut, I think it is the latches
The door is probably out of adjustment. Remove it from the power source.
Remove the top cover and examine the door catch housing. There usually are a couple of screws clamping this in place, loosen the screws, shut the door and tighten the screws.
Finaly, check the hinge for clearance, (No more than 1/10th inch), and adjust as needed.
Hope that helps.
1helpful
When I shut the door, the light stays on and the turntable keeps spinning, even though the microwave isn't on.
Issue with safety swich Door, and Relay Control on the main board ....Refer to Professional Microwave Repair ...Do not attemp to fix CAUTION HAZARD VOLTAGE INSIDE...
Door handle broke off
bru the front internal cover snaps off. you need to stick a screw driver in the edges and pry it apart being very careful to not snap it or bend the outta metal frame undo the handles screws and replace as before but in reverse
good luck
Microwave light and fan goes off until door is slapped.
This seems to be a defective door/interlock switch. There is a minimum of three interlock switches inside the oven that operate by the catches on the door. By opening the door or slapping it you are causing the to make connection.
1helpful
Hotpoint RVM1435 when I push start button will not start unit?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Microwave not working
The main controller board, or one of the power supplies has failed and require to be replaced.
You should take the microwave oven in for an estimate. I strongly suggest to not service this type of appliance yourself unless you are trained and experienced in microwave oven service.
There are many safety issues when servicing microwave ovens.
Jerry G.
2answers
Fuse
replace it with same current rating and voltage rating.just unscrew the case.
Beep
This answer assumes yours is a Hotpoint RVM1435, as posted.
If not, please reply back with your correct brand and model.
Model RVM1435 does not have a feature to turn off the beeper.
You can download Hotpoint and GE owner's manuals here:
http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
