There is also a sign of like oil bottle on the screen. and if making copy only yellow color showing but very light.
Replace the image unit yellow touch the oil can what does it say??
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
hi, clean the front roller take up ADF with alcohol and the little glass
