Question about VTech Communications CS6409 - cordless extension handset w/ call waiti
Unable to Call, Try Again
I have a VTech CS 6419 base station with 2 wireless (CS 6409) extensions in my home. When 2 handsets are being used during a call, there is no problem. But if a third handset attempts to pickup, the third handset displays "Unable to Call, Try Again." So I try again and it says the same thing every time. If I hang one of the two original handsets up, and attempt to pickup the third handset, it works perfectly, but then if I try to pickup the original handset I hung up in order to add a third phone, it then says "Unable to Call, Try Again." Is there a limit to 2 active handsets at a time? I have not been able to find any problems like this on the internet and the instruction book says nothing about whether there is a maximum number of handsets that can be active at a particular time during a call.
  • VTech Commun... Master
  • 8,081 Answers
The phone line is supplying a certain amount of power. If you open many parallel channels the power is distributed among active phones. The more sets there are the less power each one gets.These are the physical principles behind the limitations on the number of ringers a single line can activate (Ringer Equivalence Number)
As to the need to be using 3 or more sets on the same line and at the same time, I have a hard time understanding that.
For a landline, your phone company can activate 2 numbers, as it can enable A/DSL on your phone line.
Posted on Dec 18, 2013
6ya staff
SOURCE:
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
How to set voicemail into vtech CS 6419 model phone, nothing mentioned in the manual. thanks
There's nothing in the manual for the very simple reason that the CS6419 isn't a voicemail system. To setup your voicemail system, please refer to the documentation for that system.
Mar 20, 2013 | Vtech Lands Phones
My vtech dect 6.0 keeps saying unable to call try again
I had this happen suddenly on 2 out of 3 handsets with a DS6151 base and DS6101 handsets. Well, what happened is there was no dial tone on either of the 2 handsets on either of the 2 lines and a message appeared on the display "Unable to Call Try Again" after some delay, if Line1 or Line2 button was pressed.
Oddly, the 2 that did not work were the ones normally on "extension" chargers and the 1 that did work was the one on the base unit. That caused me to suspect the base unit .. which it still may have been but the solution was NOT. And, also odd, the handsets seemed to still be synched with the base unit in many respects.
Cycling the power on the base unit did nothing.
These are fairly new units and battery life is generally much longer in my experience.
The Solution:
- Remove the battery from the handset that doesn't work properly.
- Re-install the same battery.
Whatever was wrong, this reset it and the handsets started working again.
Easy fix.
Mar 18, 2012 | Vtech DECT 6.0 Digital Cordless Phone
My vtech phone says not registered and not sure why and how come? can this be fixed or do i have to buy new one? model # CS6114 S# LR605935851
Here is a direct link to the User's Manual for your phone:
http://vt.vtp-media.com/ecp/documents/product_Product/1624/UserManual/5352/cs6114_manual_i6.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 26 of the manual for detailed instructions on HOW TO REGISTER THE HANDSET TO THE BASE.
Basically, the manual reads as follows:
Not registered appears on the handset and it does not work at all.
The handset may be deregistered from the telephone base.
Follow the steps below to register the handset to the telephone base.
1. Remove the handset from the telephone base.
2. Press and hold FIND HANDSET button on the telephone base for about four seconds until the red IN USE light turns on.
3. Then press # (pound key) on the handset.
It displays Registering... and it takes about 60 seconds to complete the registration.
The handset displays Registered for a few seconds and you hear a confirmation tone when the registration process completes.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | Vtech 2653 Cordless Phone (VTECHEV2653)
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
May 06, 2010 | Vtech Lands Phones
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
I have a Vtech 2431 base station with 4 phones, one at the base station and 3 remotes, I need to replace one of the phones but I do not know how to reset the base station to remove all the phones...
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then all you have to do is re-register handsets...
Mar 03, 2009 | Vtech Lands Phones
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech M6896 phones do not work
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
Jan 18, 2008 | Vtech mi6896 Trio Cordless Phone
Open Questions:
See all VTech Communications CS6409 - cordless extension Questions
VTech Communications CS6409 - cordless extension handset w/ call waiti Logo
358 people viewed this question
Top VTech Communications Lands Phones Experts
 Grubhead
Grubhead
k24674
Bill Boyd
Are you a VTech Communications Lands Phone Expert? Answer questions, earn points and help others
