My understanding is the auger clutch lever should stay engaged while the drive clutch lever remains squeezed.
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
I encountered the same problem yesterday. It was working fine, then suddenly the auger clutch lever would not stay locked. Have you found any solutions anywhere else?
No, I have not. Although there was a website that guarenteed an answer for $15
After no luck searching the net I decided to just start tearing into it to see how the thing works and see if I could find the problem. It turned out to be pretty simple. Hopefully yours is the same. I took some pictures and will share what I found.
My solution below. Note that the cam for the drive cable keeps the locking lever from springing forward until that drive lever is engaged fully. Then the spring should push the locking lever forward to engage the auger cam lock (if/when the auger lever is pressed down).
Link for photo album on photobucket, if the pics don't show well below.http://s1174.photobucket.com/user/craigs...
Hi Mark, sounds like you have the solution to the problem I am having with my circa 2009 HS928. Could you repost your photos? They are not longer available. Thanks.
