Either your charger is not working or your battery is worn out. Had same prob. with my Acer 5532. After pricing a new one from Acer, I looked on Ebay and found a replacement with 12 month guarantee for a third of the price, so I bought the one off Ebay. Working fine!!!
I would have the battery tested to see if it has a dead cell first . Some times this will happed especasly if its over 4 or 5 years old and if it was left on a cement floor during storage witch will conduct electricty and damage the battery If the cells are OK in the battery then start checking the connections to the battery bolth posivite and negitive to the battery . If it worked before storage there is realy no reason it shouldn't work after storage . Also look for mice damage the little bastards will eat anything in the winter including the jackets off your wires so look for signs of then Good luck with it
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
This is a "flash" in the truest sense of the word, you cannot make it stay on. When the flash is charging that is happing is that a circuit in the camera is taking voltage from the battery and turning it into a much higher voltage that is then discharged when the flash goes off. You may noticed that it takes longer to charge the flash as the better is getting weaker, that is because the battery have less current to provide the charging circuit.
I think you are thinking that is can be used as a light (maybe for video mode) but this is not available in the vast majority of digital cameras.
the usb for the psp is only for tranfering data not for charging you still have to plug the original power supply charger in when your psp is connected to your pc
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Have you tried to remove the battery. If not, try this remove battery, see if that works. If removing battery doesn't work you may have to reset your player. First remove battery again, but before you put it back on, slide or hold your power on button, keep holding it down then insert battery. The load-up screen should come on asking to reboot, cleanup , or reload firmware. Just reboot and see what haps
