you will likely need to replace the following:
Duty C Solenoid
Transfer Clutch Pack
Reduction gear
All of these parts are located in the tail end of the 4EAT automatic transmissions. The reduction gear can separate from its hub and damage the above mentioned parts too.
IT is a constant all wheel drive car which means that all 4 wheels are driven all of the time . There is a differential in the centre that allows for different speeds between front and back while driving such as going over bumps . When you engage the 4wd button you are in effect locking that centre diff so that both front and rear axles drive together. If you have it so that 4wd is not engaged (selected ) and there is no drive action to the rear wheels that then indicates that the shaft in that centre diff is not connected in the side gears ( stripped /broken) and it has been in 4wd all the time so that it could be sold
The Cadillac Eldorado should have a lever or button on the side of the rear seat to enable you to fold them down.------------------------------------------------------------------------------------ Super MB STAR C3
there is a central diff(called a TORSEN diff)and yes it has splines on the output shaft.NOW this IS a front wheel drive car that goes into 4wd when traction to the front is compromised(slipping)they are not allowed to call it "quattro"or 4wd as its NOT.jack up the rear and block the front wheels,start the engine and put it into gear,the rear wheels should turn if the central diff is operating correctly.if not the best solution is to get a diagnostic done at a subaru dealer(you can then decide if you are capable of fixing it yourself or are willing for them to fix it)It is not as simple a system as some people would make out as you have electronics to control the front/rear traction.and the diagnostic computer they use is invaluable.AND EXPENSIVE.
This recently happened to my 98 Subaru Legacy Outback.
My problem is in the rear differential. May be the same for you.
When making a turn, the car sounds like a Star Wars T.I.E. Fighter. The outside wheel is not turning fast enough to keep up with the inside wheel or vice versa. AWD is disengaged and car is currently operating on Front WD. I was told this is fine to drive this way.
I have a 1997 Subaru Outback Limited wagon. I was having major issues with torque binding but didn't have $1k to fix it, so I called a couple of local Subaru dealers and asked their in-house mechanic if there was any issue with putting the fuse in to override it into FWD... both said no. They both said there was no safety issue, nor would it do any type of damage to the car. They said the only issue is that it might wear out the C-Duty Solenoid faster than usual. One of the mechanics said it might happen in 5 days... might be 5wks... might be 5mos or even 5 years... no way of knowing. It was just the luck of the draw.
I've now had it in FWD mode for almost 11mos and there hasn't been an issue one.
Did you know that there is a fuse under hood on Passenger side that I have seen people put the fuse in the missing spot. Problem is it is only for towing the car. Remove if fuse is present and see if it fixes your problem.
