Problem Event Name: APPCRASH Application Name: iexplore.exe Application Version: 8.0.7600.16385 Application Timestamp: 4a5bc69e Fault Module Name: StackHash_ab37 Fault Module Version: 6.1.7600.16385 Fault Module Timestamp: 4a5bdadb Exception Code: c0000374 Exception Offset: 000c283b OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: ab37 Additional Information 2: ab3770e1c3ef5fbc753dcb2d1269347d Additional Information 3: 3579 Additional Information 4: 3579c45425b22b78f8464a7675b51b46 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
SOURCE: Problem signature: Problem Event
Try this
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
SOURCE: Close the Programe (Notice)
User permissions issue. Go to C:\program files\microsoft\fsx and find the fsx.exe icon. Right-click it, choose properties, and tick the check box for "always run as administrator". This process doesn't always work doing this from the FSX shortcut.
SOURCE: windows 7 problem
try to connect the usb HDD in windows with safe mode(by pressing F8 while booting ) and try to check the HDD system disk by windows tool, this might solve some errors. and restart ur device & can work normally then, if windows found errors on ur harddisk & fixed them. good luck
