One of my turntables seems to speed up and slow down by its self without moving the pitch control
I'm afraid it could be many things, most likely nothing to do with the pitch control. I believe you have a Direct Drive motor, so that maybe bad. There is a circuit that operates with a microprocessor(computer) IC, called a Phase Lock Loop, which is what keeps the pitch accurate. Anything there could be bad. More more information, or should you have more questions, please visit my website at audioserviceclinic.com. I may be contacted through the website. Thank you.
SOURCE: broken pitch control
Yep, time to replace the pitch control. You can attempt to do this yourself, however good soldering skills are required (not the time to learn). You will have to desolder the old pitch control, and solder on the new one. Which is why I say, now is not the time to practice soldering on your turntable. You could actually cause more damage.
If after replacing the pitch control, you still have the same issue, then there is something wrong with the drive on the unit. The drive is controlled by various integrated circuits (IC's), and they are known to short out every now and then. The problem is isolating the correct IC. FYI, Technics is starting to discontinue parts, and 1 of the main IC's on this unit is no longer available (IC302 - Nand Gate).
You can order the PITCH CONTROL HERE.
DJ PRO LAB
www.DJPROLAB.com
