Cannot select sani rinse cycle
SOURCE: I have a KDS-18 dishwasher, and had been working
in your onwer mannual there is a number call kitchen aid they will walk you through the steps to reset your unit
SOURCE: washer continues to run
Switch off and restart on such events. Check main plug & socket for a firm contact. There should not be any loose contact!
SOURCE: KitchenAid Dishwasher KUDS01IJ will not
couple things you can try first hold down cancel for ten seconds this usually cancels the cycle and puts the unit in the drain function or you can try hit high scrub and than energy saver and repeated the same after a few seconds or if this also doesnt work then you could also try shutting of the power by way of the breaker for 5 minutes which usually causes the controler to reset if none of these tests work message me back and we can perform other tests also how many times are the lights blinking if its 3 times then these tests should correct the problem if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
