I have a Ryobi RY6051A that I bought in 2007. I have drained and started with fresh gas oil mix, this year. I also have changed the spark plug. In following the starting instructions, I push the choke switch to the start position but it will not stay in the start position. When I pull the rope, it is definitely getting gas and fires, but does not start. Do you have any suggestions? Thank you.
Hello:
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
