With dual labels it only prints on one
SOURCE: My Eltron LP 2824 won't print two labels side by
Your software drives this...not the printer. What software are you using to print the labels?
SOURCE: Eltron 2844 prints previous job over and over
Make sure the label size is correct, if the print encounters a gap before it is complete; it will re-print the same label. In MS Word make sure the page size is set to the correct size including any headers and footers and Width etc.
SOURCE: Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
