I removed the majority of my playlist from my sansa e260. when i disconnect the player ALL of the songs are still in my song list despite being deleted AND they won't play (bad track message). when i tried to sync new songs through windows media player i get an error for almost every single song. i know there is nothing wrong with the format because some of them i had on my player before. helllllllppppppppp!
SOURCE: Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
SOURCE: sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
SOURCE: Philips GoGear SA3245 - Playlists Not Showing Up on Player
a letter i received from the Phillips Consumer Care:
We understand that you were unable to sync the playlist you created to
your Flash audio player. Please be informed that this unit is unable
to support playlist created on the computer. The playlist must be
created on the device. Please click on the link below to access the
user's manual:
http://www.p4c.philips.com/files/s/sa3245_37/sa3245_37_dfu_aen.pdf
Please refer to page 10 for information on what buttons to push to add
or delete currently playing song to list. Please refer to page 17
which shows how to to view songs in list.
