Question about Lanier Office Equipment & Supplies
Service code 561 error
Lanier LD425C copier is producing an error code saying sc 561. What can I do?
    President:
  • Lanier Master
  • 990 Answers
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
Posted on May 15, 2009
  • architect11 Oct 19, 2010
    where do you enter the value?
  • Alexander Poggensee Jul 11, 2012
    thanx for the helpful solution. But what and where is the thermopile at MP2500?
    Greetz from Hamburg
SOURCE:
How to print enevelopes without them jamming in a lanier ld425c
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
Aug 28, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Lanier LD425c touch screen does not function
You can try to adjust the touch screen > press the yellow clear button then 1993 & press the stop button three times & follow the display screen. Odds are you are going to have to replace the touch screen, the adjustment will not last long....Good Luck
Dec 22, 2012 | Ricoh Lanier Ld445c Ld435c Ld430c Ld425c...
Why am I getting lines on my prints when I go thru the top feed of my Lanier LD425C?
Clean the **** glass. It is a long skinny glass to the left of the big rectangular glass under the feeder. Clean it and your problem should go away.
Aug 30, 2012 | Lanier Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Sc 546 lanier ld
This is a fuser error code resetable by entering service mode. -Carl
Jun 10, 2010 | Lanier 1205 Copier
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Feb 11, 2008 | Office Equipment & Supplies
2,338 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
