Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Scans are enlarged after switching to vista 64bit
I switched to vista 64 bit on an hp touchscreen and now with the updated driver the scanned images are enlarged so 1 letter size pg becomes 6 pgs to get the whole document
    Sergeant:
    Champion:
  • 240 Answers
Hmmm... just the set pixels properties to medium..maybe the pixels properties is to high..it can cause long time scanning and large images results ..thank you
Posted on May 15, 2009
SOURCE:
Black lines on scans and prints HP 2727nf
File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
I have an HP laptop OS Vista i tried to
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Sep 03, 2009 | Canon CanoScan 5000F Flatbed Scanner
I cannot install to my computer with Vista with 64
The problem cannot be solved. You need to give more information.
Firstly, do you have a 64bit PC? If so then is the Vista disc you have, an upgrade disc or an OEM straight install disc which requires no OS on your PC to install Vista 64? If it is an upgrade disc, then you need a qualifying OS, on your PC to upgrade it to Vista, for eg. WinXP, Win 2000, etc. If it is an OEM Disc then maybe the PC cannot find the disc to boot from when you switch on your PC. Get into the PC's System Bios and set the boot order so that the CD/DVD disc drive is scanned first rather than the Hard Disk drive of your PC at switch on. Then save the settings and exit the system Bios. To get into the system Bios you need to either press the 'Del' key or the 'F2' key when the PC is switched on.
Jul 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Apr 11, 2009 | Brother MFC-8660DN Network Mono Laser AIO...
Vista 64 bit os will not install my canon mf3200 printer
Most of the software nowadays are only works for 32Bit operating system, you could try to check the availability of 64bit driver of your Printer from the manufacturer's web site.
Mar 14, 2009 | Canon MF8180C Color Laser MFC Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
53 people viewed this question
Clive
Clive
old marine
old marine
