Need to replace a zebra rw420 motherboard because the mini usb port is detached
SOURCE: Windows Mobile 5 and RW420
I don't if this matters for Windows Mobile or not but there is no driver listed for it based on the website:
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7
The problem is that Zebra printers use a PCL language to print with. Forms have to be programmed
into the computer being used. Then they are downloaded into the application you are printing with.
These printers are designed for label and invoice use. The applications designed for them send the
data over. They use them for delivery services to print with. I know bakery trucks use these in the vehicle.
There not designed for straight text printing.
If you have ever seen label printers that they use for shipping out Fed Ex and UPS, that's what this
printer does.
If you go to this link here you can get an idea as to how they are programmed:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.html
If you have any questions about programming forms for them, let me know. I had to go to a
special school in Atlanta several years ago to learn how to do that.
SOURCE: USB PORT FOR ZEBRA Z4M
It will not work with any drivers if you do not have a parallel port. You can get a pci card that has parallel port on it for use with the zebra z4m.
below is a link for the card that cost only $9.99
http://www.gogocost.com/xcart/product.php?productid=275
SOURCE: how to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
SOURCE: replace the usb ports on an acer aspire 5532 laptop
You need to dismantle the laptop completely to get to the motherboard so you can replace the USB socket.
