You say all power went out but it is not a breaker. What power went out? In your kitchen? house? or just the machine? Can it be that you are plugged in a circuit that is protected by a GFI?
There normally is a fuse inside an oven on the floor. Unplug the device, remove the cover. DO NOT TOUCH THE SILVER CAN IN THE BACK - LETHAL.
Check the fuse with an ohm meter or contunity checker of some type.
If you need additional assistance, please let me know.
I hope this was helpful for you
a
SOURCE: Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
SOURCE: tripped a breaker
sometime the kitchen has gfc outlets around the walls and one of them tripped. but not likely , it sounds like the microwave fried some valuable circuitry.
