Olympus VN-2100PC Digital Voice Recorder Logo
A
Anonymous Posted on Dec 17, 2013
Codec 32bit windows 7 - Olympus VN-2100PC Digital Voice Recorder
2answers
Is a canon MG3029 compatible with an ACER that has windows
Yes. But your version of Windows could be a problem.. lemme see.. Nope, no problems:
Operating Systems:
  • Windows 10 (32bit)
  • Windows 10 (64bit)
  • Windows 8.1 (32bit)
  • Windows 8.1 (64bit)
  • Windows 8 (32bit)
  • Windows 8 (64bit)
  • Windows 7 (32bit)
  • Windows 7 (64bit)
  • Windows Vista (32bit)
  • Windows Vista (64bit)
  • Windows XP
Hp 520 notebook
Double click on the sound at the bottom right hand corner and pull up your sound properties. Make sure that all of the boxes are un checked ensuring that your sound will work.
Transfer pictures cardreader
can u give clarification? u want to send picture to memory stick?
I have one installed Windows 7 64Bit version on my PC with product key registration and all legal. I then installed a new HDD and installed another Windows 7 32Bit on that HDD, also this with it's own...
If you have 2 HDD and one with Win7 64bit & one with win7 32bit. Try to boot in command prompt by pressing F8 during boot up.Forrmat the HDD you dont want. If it doesnot work. you need fresh install. Before doing any thing make sure you backup your files. Note: Try Factory reset option first. it is the best option.
How to get correct codec
For simplicity depending on your Windows Operating System(OS), easiest is just to install "K-Lite Mega Codec Pack or K-Lite Codec Pack" codec. These packages are compatible ot OS(XP, Vista & Win7 - 32bit(x86)). If your system is 64bit(x64), you can also download & install the 64bit version too. You can install both 32&64 bit versions together if your OS is 64bit.
Hope it helps.
Hi, I have a Canoscan 9900F. I have a problem when installing it on a new Windows 7. Do you have any new driver for my scanner? My name is Joga, I live in Indonesia Thanks
i have the same problem with this scanner
but you cannot do any thing Joga
problem is windows 7
i have both of Windows 7 (64bit) and Visa (32bit)
and use Vista when i want to use scanner
you can buy a new scanner to solve this problem with windows 7!
Drivers only available for Windows XP (32bit) and Vista (32bit):
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_9900f#DriversAndSoftware
1helpful
Intel 845 Graphics driver is not working in Windows 7 what to do?
Hi
You need to obtain a windows 7 driver for it, or if one is not available then use a vista driver, make sure the driver is 32bit or 64bit depending on the type of your system.
if your windows 7 is 64bit, then you can't use vista 32bit driver. you have to use a vista 64bit driver.
Or if your windows 7 is 32bit(most are) then you have to use a 32bit driver, the 64bit wont work in that case.
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
