My car ran just fine with no problems or check engine light on. One morning my husband went out to start it as he normally does before work. It started right up with no problem and then a few seconds later it died. My husband tried to start it up again and it acted as if there was absolutely no power going to anything/nothing works at all not even lights. We had the battery, starter & alternator checked and they are in good working order. Does anybody know what might be going on? Thanks
SOURCE: 1994 Plymouth Acclaim 2.5, 4 cyl won't start
on the backside of the alternator there should be a large black/grey wire. check to see if there is battery voltage on that wire. If there is not than you have a blown fusible link that is inbetween that wire and the battery. If there is power there than check for power on the dark green with dark blue wire. There should be power anytime the engine is running. If there is no power than there is a problem with that wire in between the alternator and the ASD relay.
Check those two out and let me know what you find.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
tell individual working on it to check the crankshaft sensor voltage and signal when it wont start also check the fuel pressure and cam sensor, these are all possible problem with that particular car. it also has wiring issues that an expert tech would have to diagnose
