There must be something wrong with a sensor or something because the ADF doesn't recognize that I put paper in it.
SOURCE: Ricoh FT5535 paper misfeed
I know your Ricoh. Your problem simple. However me it is difficult you tell in internet.
Let's on order. I Sergey, My experience of the work 18 years. Rico although and good копир, however moody. Here, it is difficult without skilled help. I have understood so that beside you stick the paper in enterring трэке. And with hands direct move and with pallet. Then listen. I shall enumerate причичины, but in afterwards check.
1. Vysoh giving roller.
2. The Substrate, which is found under rubber roller or is damaged or disappeared.
3. Exists the damage to axis of the presenting the paper and she on adjoins to paper exactly 4 Simply there is hindrance to passing of the paper 5 Sensors of the entering the paper or is littered or small flag sensor came out of jack and his(its) has wedged 6 Nakonc, most probably, this only in device Ricoh - on axis, which provides in motion feeder, seizes the paper, on which roller, on the part of opposite front behind there is bushing of the joining, she provides in motion roller joinings and stretches the paper. This bushing of the joining устроета thereby that she abrades or is polluted by dust. It is Necessary to remove the back cover, get before this bushings to see her(it). Otkrfti front lid and put(deliver) the stub on sensor to make lid and look, what operates the mechanism of the drive in moving the axis on which is located roller of the presenting and tracktor of the papers. Attentively define in what time stops the paper. Advisable give the paper with hands without pallet. If you find that gross does not revolve, but щелчQк there is, you necessary to analyse the bushing which on axis and wash the alcohol and define her wear-out, otherwise her(its) zameniti. my address goodgold@inbox ru Sergey. Write
SOURCE: I'm trying to copy an original 2 sided document.
I suspect that the 'turn around gate" is not actuating. they mechanism can become dry and get stuck. Often a simple fix is to open the left cover of the feeder (feed in section), then lift up the top tray where you place the originals. You will see a black panel which is the "gate". Simply press on this and it will move down and the spring back up when released. That is often enough to free it up for the short-term; however you may need to do this after a period of non-use, as the solenoid that actuates it, bushings etc., are dry.
I hope this helps.
Please let me know, and rate solution
SOURCE: Ricoh MP 3500
Ricoh is having a major problem with touch screens on a lot of the newer machines. Contact a dealer to see if yours is one of them and for replacement.
SOURCE: remove paper from adf error ricoh aficio 2020
Clean the paper sensors and move the actuators.Open and close front door to reset malfunction.
SOURCE: Ricoh MP 5500 changes 8.5 x 11 documents to legal size on scan.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
check the original detection sensor and actuator
