Apple iPod nano Logo
Kerri Sanders Posted on Dec 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just want to know which iPod nano I have
Pink, slim, have 171 songs, . Says I have 6.6 GB free left
Jim Thomson
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Apple Master 1,099 Answers
  • Posted on Dec 17, 2013
Jim Thomson
Apple Master
Level 3:
Renaissance:
Answers
1099
Questions
0
Helped
275802
Points
2710
Have a look at http://support.apple.com/kb/TA38528 particularly the section on settings under About, you should be able to see what model you have there. Hope this helps.
3 Related Answers
Anonymous
  • 28 Answers
  • Posted on Mar 15, 2008
SOURCE: problem with my apple ipod nano pink A1236
Are you using Apple Itunes?
Anonymous
  • Posted on Oct 26, 2008
SOURCE: Drivers for IPOD 4GB PINK
I want drivers for I pod 4 gb nano !
jazzyboy11
Jazz Boyce
  • 728 Answers
  • Posted on Apr 26, 2009
SOURCE: Deleting songs from Ipod Nano 8GB
When you connect the ipod nano to the computer, you can do one of two things: you can go to the ipod's main home page in itunes and go to the bottom where it will have four options listed. 1 of them should say manually manage files. Click on the check box next to it and it should ask you if you are sure and click yes. Then go into your music folder of your ipod and delete the songs you don't want on there. To add music, all you have to do is click and drag what you want onto the oped. The second way you could do it is to go into your library before connecting your nano to your computer and un-checking all of the boxes next to the music you do not want on your nano and then connect it to a computer and let it sync. The first way is easiest and less time consuming as you only have to do it once. Hope this helps!
How to install song
connect your ipod to computer
open windows explorer
copy song from computer and paste at ipod drive
after copy disconnect ipod from computer
and you got the song
1helpful
Memory loss on ipod
The ipod nanos the smallest product in the Apple iPod line. The fourth generation Nano comes in two different capacities, each capable of holding thousands of songs.
    Capacities
  1. The fourth generation iPod Nano comes in 8 GB and 16 GB models. The 8 GB version can hold 2,000 songs, and the 16 GB version can hold 4,000 songs.
  2. Tips
  3. Song capacity estimates are based on music encoded in Apple's proprietary format at a standard, average bitrate. The higher the bitrate, the better the quality. Songs deviating from Apple's standard (for example, CD-quality music or high bitrate MP3s) will use more disk space.
  4. History
  5. Nano's predecessor, the iPod Mini, was released on January 6, 2004, and was available with a 4 GB hard drive. The Nano was first released on September 7, 2005, and was the first iPod to use flash memory. It was first available in 2 GB and 4 GB versions. The fourth generation Nano was released on September 9, 2008.
  6. Size
  7. The fourth generation iPod Nano is 3.6" tall and 1.5" wide.
  8. Video
  9. The third generation Nano, released on September 5, 2007, was the first Nano to feature video playback. Storing videos on Nano can dramatically reduce the amount of songs it can hold.
Apple nano silver 2 gb
Use iTunes 8 to sync or delete songs, photos, etc. Just connect the iPod to computer, download iTunes 8 from the internet, open iTunes 8, and then double-click on the icon of the iPod Nano to Sync files to your Nano.
The manual for the iPod Nano can be found at www.apple.com/support
2answers
Downloading music from computer
Musicmatch songs won't work on Ipods. Musicmatch has been discontinued since it was acquired by Yahoo last year. If you have songs in MP3 format those can be used in ITunes.
2answers
Wont show songs on ipod
your probably trying to play the wrong playlist on the ipod.
What is the difference between the iPod nano and iPod mini?
The currently shipping iPod nano replaces the iPod mini. Both models use the "Clickwheel" (which places pressure sensitive navigation buttons underneath the scroll wheel) introduced with the iPod mini, but the similarities between the iPod mini and iPod nano end with the "Clickwheel". The iPod mini shipped in a colorful "ultra-portable (3.6 inch tall, 2.0 inch wide, 0.5 inch thick) lightweight anodized aluminum" case available in five stylish colors--silver, gold, pink, blue and green (four colors from February 23, 2005 to September 7, 2005 with gold no longer offered), each with a 1.67-inch "white backlit" monochrome LCD display. The iPod mini has either 4.0 GB or 6.0 GB hard drives to hold approximately 1,000 or 1,500 songs (encoded at 128-bit), respectively. The iPod nano, on the other hand, ships in a "impossibly small" 3.5 inch tall, 1.6 inch wide, and 0.27 inch thick "iBook white" or jet black and stainless steel case with a 1.5-inch "blue white backlit" 16-bit color LCD display. The iPod nano has either 2.0 GB or 4.0 GB of solid state Flash Memory and can hold approximately 500 or 1000 songs, respectively, in 128-Kbps AAC format and up to 25,000 "iPod nano-viewable" photographs
2answers
Nano VS. Mini
Nano VS. Mini
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
