Canon IXY 1000 Digital Camera Logo
Posted on May 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not ale to dowload photos to my laptop
Whenever i try to download the photos to my pc...the photo and scan wizrd shows "no photos on your camera" whereas there are so many old and new photos on my camera.the sd card is not locked ,battery is fine..i don't know what is the problem.i have tried on 2 PC's but the message is same
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Nov 11, 2014
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428978
Points
622693
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
5 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Jul 07, 2008
SOURCE: Hi whenever I take photoes on cannon powershot sd 500, 5.1mp the image is getting blurred and horizontal stripes appear
This looks like a processor fault, or an internal RAM fault. You should send the camera back to Canon for service.
Jerry G.
Anonymous
  • 51 Answers
  • Posted on Jul 15, 2008
SOURCE: the image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
Anonymous
  • 14 Answers
  • Posted on Aug 21, 2009
SOURCE: Whenever i am trying to take photos it's showing battery is low.
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Anonymous
  • 161 Answers
  • Posted on Dec 14, 2010
SOURCE: Cant download photos off SD card. When I try to
First check the tab on the card, you might have just accidentally pressed the tab. It makes it 'read only' kind of like the old floppy disk (A disks for computers). If this doesn't solve it your pictures are gonners.
You can reformat and it should be good as new. If that doesn't allow it, then its your SD card being corrupted.
  • 102366 Answers
  • Posted on Sep 10, 2012
SOURCE: communication error message on my canon s100
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1helpful
2answers
Lost photographs trying to downloading on my lap top is there any chance of recuperating images from my compact flat card
most cards DON"T lose the images - you can usually download recovery software from the Card manufacturer.
3answers
Photos deleted
GT Recovery for Windows Download: www.gtrecovery.net
GT Recovery for Windows is a professional data recovery for PC and Android phones. It can restore deleted photos, videos, audios, documents from PC.
Whenever you lost important photos or deleted photos by accident, you can use it to scan and recover the photos on your phone.
Application Software
try to download the software from the company website.
1helpful
3answers
Lost all my pictures on my camera...suppoose to be saved on my san disk...how can i retrieve my lost oicture
Hey, first thing to do is stopping to use the camera.
Take out of the card and connect it to PC. Download Card Data Recovery, which is a professional photo recovery program. Launch it and use the function of recover photos.
Does the Olympus FE-230 date stamp the photo when dowloaded to PC? If so, please advise how. I have downloaded some photos and date and time are not stamped on photo. but on the camera it shows date and...
The camera stores the date and time (and a lot more) with every image in what's called the EXIF data. Any competent photo viewer on your computer should be able to show you some or all of this data. If you want the date printed, that's up to your printing program. Depending on the program (and printer), you can have the date printed on the image, in the margin, or on the back. Please refer to the documentation for the program.
51helpful
12answers
Xias DCS-760 Digital Camera: how to recover deleted photos from norcent camera...
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
I put memory stick duo into laptop now am not able to use camera.
It sounds like the photos are downloaded onto the pc... the access might mean that the memory card is empty. Turn the selector wheel on top of the camera to the mode that you take the photos on and try taking a picture. Make sure the card is in the right way first. Also the next time you download the photos just make a new folder on your desktop and label it photos. Insert the memory card open it and highlight one photo then press cntrl and A ...this will highlight all the photos in the folder then drag them to the new folder it will remove the photos from the card and place them in that folder on your pc. hope this helps
I cannot open the pics taken in my canon a460 camera into my pc
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Viewing photos on camera after downloading
your memory card has a virus! try formatting using camera. make it a habit that whenever you reinsert the memory card in your camera format it first before taking shots, this will erase everything including virus!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
