Video Game Consoles & Games Logo
A
Anonymous Posted on Dec 22, 2017
Karcher 1402 red light keeps flashing even when i have water in it then no steam have only used it for about 15 mins tops before it happens have to turn it off at mains and wait for ages to begin agai
Red light keeps flashing even though the front resavoir is full have to keep turning off at mains and waiting no steam when this happens only used it today and it is proving very hard work can only get about 15 mins use from it before this keeps happening and i have to wait a good couple of hours to start again
5 Related Answers
Anonymous
  • 709 Answers
  • Posted on Sep 27, 2007
SOURCE: Red Ring / System Crashes / Doesn't Start
Hi Kashman, The industry is trying real hard to come up with a solution. Microsoft has extended the wrranty for people like you. Problem is that I hear they just send you a refurbished unit that will do the same thing eventually. Best plan i have heard is to do things to keep the Xbox as cool as possible. Currently I am not sure what to do with the Slow boot up. Keep it in open air area and out of sunlight. It helps to allow a fan to blow on it during play.
Anonymous
  • 30 Answers
  • Posted on Nov 10, 2007
SOURCE: On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Anonymous
  • 319 Answers
  • Posted on Jan 02, 2008
SOURCE: after 20 mins of play console turns itself off and red light flashes
There are some known issues with the PS3 overheating.
Be sure that there is plenty of room around the unit. ie; not directly under or over another piece of electronic equipment, it needs room to breathe!
There are numerous suppliers of "intercoolers" and fan systems to help cool the unit available for around $20.00.
If you have a small fan, you may want to try it on the unit to be sure that this is indeed the problem!
Good Luck!
Papa0106
  • 13 Answers
  • Posted on Feb 28, 2009
SOURCE: Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Anonymous
  • Posted on Mar 15, 2009
SOURCE: Red light blinking on PS3
If your having this problem I know how to fix it but only for about 30-45 seconds.
Okay this is what you do.
1.If your ps3 is turned on press the red button , it should turn green then yellow ,beep and blink red.
now do this 3 times without turning it off.
2.Turn your ps3 off.
3.Turn it on while holding the eject button.
4.Now your ps3 should stay on ,(like I said for about 30-45 seconds).Also the fan should be on.But then after a while it turns back off.And that's as far as I got.
(It really works if you do it right)
1helpful
3answers
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
1helpful
Karcher sc 952 having problems with no steam coming out.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
1helpful
Saeco Giro II Red Light stays on, even after removing watertank, dredge drawer and brewing unit, and replacing. Red light does not flash after removing dredge and brew unit.
Had the same problem, if you used steam or hot water, make certain the steam knob on top is all the way back in the close position, if not the red exclamation sign will stay lit.
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
On my ge answering machine, the CL red light keeps flashing even though there is zero msg. so how do I clear this CL red light flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
1helpful
5answers
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
2helpful
4answers
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
2helpful
Water filter light
Try to hold in the button for water/steam for 15-20 seconds.
Top Karcher Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Karcher Video Game Console and Game Expert? Answer questions, earn points and help others
