SOURCE: LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
SOURCE: SAMSUNG SP-P4251 DISTORTED PICTURE AND THEN SCREEN GOES BLUE
Wow same here but mine is red I know its because of the plasma bulb is wearing out and for my fix is $1000 but I didn't do want to go on so I tried to change the color settings and tried RGB to all 0 and it became fine. Well at least you have a cool blue screen, mine is red.
SOURCE: samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
SOURCE: Samsung LCD TV colour distortion
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1300 posts to different brand TVs now. Pull up
older posts there.
SOURCE: my 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
